How Straight is Your Tailwheel
Postby Direct C51 » Tue May 10, 2016 2:08 pm
I just completed my tailwheel assembly with the Sonex 6" machined tailwheel. As careful as I was to drill the tail spring precisely straight, it somehow got canted in the multiple up drilling. With the tailspring bracket on a level surface, the tailwheel is canted 7 degrees. I would imagine the tailwheel will naturally want to be level, causing it to steer 7 degrees to the left. How close did you guys get your tailwheel, and has any cant caused ground handling troubles?
Direct C51
Re: How Straight is Your Tailwheel
Postby Bryan Cotton » Tue May 10, 2016 2:36 pm
Mine is pretty straight! Screwed up, welded a sleeve on, got it right on try 2.
Postby Darick » Tue May 10, 2016 8:51 pm
Yep, mine is off a bit too. I would imagine it would eventually wear to the degree that it is canted. I intended to see how bad it taxied before trying to make it perfectly straight.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby fastj22 » Tue May 10, 2016 9:12 pm
You will want it straight. Mine is slightly off and it pulls a bit to on side.
Postby DCASonex » Wed May 11, 2016 7:17 pm
The tail wheel is designed offset like a caster, and tries to act like one. Canted to the side will definitely have an adverse effect. If you have a common swivel caster around, hold it by hand and tip to one side. That should provide all the convincing you will need.
David A. Sonex TD
DCASonex
Return to Sonex Plans
