peter anson wrote: I eventually fixed it with bog rather than an oops.
To help educate me, can you elaborate on what a bog is?
peter anson wrote:To help educate me, can you elaborate on what a bog is?
Gosh Kevin, don't you know any technical terms? Sometimes known as DeSoto PR Compound, PR-1422 Class is a two-part, dichromate cured polysulfide compound for sealing fuel tanks, or more technically, BOG.
As you can see, it even looks like BOG.
kevinh wrote:peter anson wrote: I eventually fixed it with bog rather than an oops.
Hi Peter,
Kevin
Not to be overly critical, but the teflon tape you have used on the fuel selector valve is a never, ever, ever, use item on any fuel lines or fittings. There are so many NTSB reports fatal accidents caused by fuel starvation as a result of using this its not funny.
Users browsing this forum: Google [Bot] and 76 guests
