Johns wrote:There was a pressure adjustment on the rear relief valve that was set to high. I fixed that.
Johns wrote:Now I have leaks from some of the pushrod tubes on the right side. I'm guessing as a result of the high pressure.
Johns wrote:Thanks everyone, I have a set of the two piece( the screw together kind) on order.
Mike, I was thinking of using Permatex when putting things back together. You just made up my mind.
Any suggestions on the easiest way to remove the existing tubes without removing the heads?
John
vwglenn wrote: It's almost always better to lean towards German or OEM stuff.
The white pushrod gaskets are better than the red ones in my opinion. They stay softer and seal better.
Users browsing this forum: No registered users and 25 guests
