kevinh wrote:The point about 'slightest' twist is a good one. I resorted to using a thick very flat/no twist piece of plywood on top of my workbench and that worked great.
Sonex1243 wrote:kevinh wrote:The point about 'slightest' twist is a good one. I resorted to using a thick very flat/no twist piece of plywood on top of my workbench and that worked great.
Kevin, dumb question, were you referring building flat on the work bench? I pilot drilled / built the controls flat on the (leveled) bench on the hinge side first so I could position and drill the hinges over a strip of .025 and .032 to set the .057. Then flipped them over and piloted the other side.
Users browsing this forum: No registered users and 91 guests
