Spar caps clean up
Spar caps clean up
Postby lstinthot » Tue Apr 26, 2016 6:49 pm
We are about ready to take the spars apart and begin deburring and cleanup process.
Waiex spars on left, scratch built Sonex on right
Are we supposed to clean up the milled edge where the tie down is installed? This would allow the piece to sit flat, but does it take away from the strength of the spar cap? Does it matter?
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Re: Spar caps clean up
Postby Bryan Cotton » Tue Apr 26, 2016 7:33 pm
Looks good. I did sand mine down so the angle would sit flat. I think the reduction in strength is minimal. Bending loads primarily go through the vertical section so that bump will not add much.
Postby Sonex1243 » Tue Apr 26, 2016 8:10 pm
I had asked Sonex tech support the same question and they said go ahead for a good flat fit.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby lstinthot » Tue Apr 26, 2016 8:45 pm
I was leaning toward cleaning them up so the parts sit flat. Thanks.
Tail dragger
lstinthot
Postby lstinthot » Thu Apr 28, 2016 11:08 pm
How about adding a shim under the tie down. Allows the tiedown to sit flat. What say the crowd?
Slight gap that could be worked to remove it.
Here you can see the shim.
Tail dragger
lstinthot
Postby Bryan Cotton » Fri Apr 29, 2016 7:19 am
That would work too, if sanding down that spot bugs you. I saw it as a weight reduction opportunity! I read Paul Dye's column in Kitplanes yesterday and he is right, I should lose 20 lbs. By God I'm trying but injuries have really messed up my running. So, I go after those micro-oz wherever I can.
Postby kmacht » Fri Apr 29, 2016 10:12 am
I did the opposite and filed down the angle tiedown piece a little bit rather than trim the spar. I figured I wanted the little bit of extra material was better on the spar than on the tiedown.
#554
kmacht
Postby lstinthot » Fri Apr 29, 2016 11:41 am
I was thinking about trying removing material from the tie-down angle to make it sit flat. The shim is less than .025" thick. It would not take that much time to channel out the relief for the spar edge. I'm going to finish cleaning up the spars and try a few different options to see what I like best.
Tail dragger
lstinthot
Return to Sonex Plans
