by n502pd » Thu Apr 28, 2016 7:31 pm
OK, John and Chris! I may have nothing to worry about. The heads and case arrived this PM. the case does indeed have a hole in it, and it looks like it has been 'worked some already. There is evidence that a crank somewhere was swung inside the case as lots of material has been removed for clearences. I shall check further for sure. There is some dremell work to do on the outside of the case as it is rough in places, and the flashing on the heads between fins and such needs removed.
Now I have lots to do...finish wing install and set them aside. Begin engine clean9ing.
One other thing...paint. I am going to paint the iron cylinders high heat black. I do want to paint the case for corosion protection, but I have seen others with no paint. your opinion on case paint? (Ha...I still have some gold engine paint from my O-300A rebuild and I am thinking that!!)
Thanks much again!!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
