bakfly wrote:An Aerovee with the Aeroinjector idling rough is not normal.
bakfly wrote:After I got a new #2 needle with the correct diameter from Sonex (after first trying with a borrowed one) and a few adjustment
it is a different engine.
bakfly wrote:An Aerovee with the Aeroinjector idling rough is not normal. Most likely the needle is faulty.
Onex107 wrote:I've posted on this several times, but it needs repeating. Tighten the ball socket in the needle holder and measure the dia. of your needles. A needle that is .001 under the .125 diameter is difficult to adjust at idle because the fuel is leaking around the diameter, not just on the flat side. Some of the older Aeroinjectors came with brass needles. I had new needles made from drill rod that is exactly .125. The flow at idle is small enough to be effected by this. I think the dealer needles are made from "wire" that has a larger manufacturing tolerance than drill rod (it's less expensive), and my needles varied from .001 over to .001 under. In my case, I went on to the #3 needle design, which gives me an excellent WOT and IDLE at the same mixture setting. I only adjust the mixture at cruise to raise the EGT a little and don't touch it again until the next flight. 103 hours and counting.
Users browsing this forum: No registered users and 105 guests
