by LarryEWaiex121 » Wed Apr 20, 2016 6:58 pm
Mike,
As you so carefully pointed out, the number one reason folks have difficulties with the Aero-Injector is failure to follow the instructions and more importantly, the "sequence" of how to tune the unit. This is meant to be helpful and nothing else. If this helps, great. If not, it didn't cost a thing and I'm not here to debate which carb works better. Simply, if done according to the directions its a great unit, with few moving parts.
I tried on about half a dozen occasions to assist individuals and found one common thread. Seems most were concerned with making the engine idle smoothly on the ground before doing the open throttle exercise. Doing so is a complete waste of time unless you magically hit the sweet spot by accident. The effort needs to be tune for full throttle and manage your mid range and idle through mixture. Sometimes it works out that a person can stay full rich at all three ranges but that's not the norm and only a goal that can be overcome with mixture if it doesn't work out as such. Being full rich for all conditions tells me there is no ability to deal with much of a leaning condition such as flying to a lower elevation airport.
The instructions clearly state the engine needs to hold full power and be able to enrichen the engine and lower the egts by 100 degrees. If not your too lean and need to raise the needle. If one needs to raise the needle more than about 1 1/2 - 2 turns then a larger # needle is warranted. The problem with continuing to raise the needle is it will typically make the mid range and idle way too rich. Better to have a larger needle and have the correct needle height. I know many have modified their taper but thats a whole other story and fly's in the face of the "follow the instructions" theory I presented up front.
In my case, I use the #3 needle at the specified height + or - about a turn. Can't honestly remember. This makes the engine slightly rich at full rich mixture at all three ranges. Full open, mid and idle.
One simply starts the engine full rich and upon startup, I pull the mixture control about and inch and she purred like a kitten.
After run up and taxing into position, one goes full rich for departure.
This setup procedure has been beat to death for many years, but again, I will state that the great majority of individuals I've encountered wanted to fiddle with idle and such first and that's dead wrong. That and the fact that before trying explicitly what the factory recommends, they want to in some way deviate from the factory stated instructions. Both from a tuning aspect and an installation/modification aspect,
I wouldn't leave the proven path until that part of things is done as well as possible. Once the unit is set up within reason, and some practical experience is had, a person can experiment a bit here and there but its important to get the basics well established.
After experimenting with #3 needle I tried another one (2.5 I believe) and never was able to get enough top end, rich mixture and went back to the #3. I had it there and unchanged for over 400 hours of operation from sea level to 10,000'.
My normal field elevation is about 2,300' and at sea level, rather than change the needle height, I could keep the egts in range by bringing about a half inch of throttle out of the equation(less air and same fuel) and the rpm never varied, but, the egts would drop about 100 degrees to the 1250 range.
Once a guy fully understands the operation of the Aero-Injector, only then do you begin to appreciate the benefits of no floats, no more jetting probably ever, no carb heat installation needed. I've been in every combination of humidity, temperature, icing one could imagine and never a hint of carb ice. The level of simplicity and ease of service makes it worth the effort to get it right and then just fly it.
Larry
Waiex121YX, Cammit 3300 almost ready to fire off.
