by DCASonex » Sun Apr 17, 2016 9:29 am
Did some investigating years ago when learned of the folding (in-flight) wing problems with the Zenith CH650 I started building. Found that the aluminum Axex pull rivets (available from ACS), that Zenith uses for the entire air frame, are designed to form a bulge, and then draw that bulge back to clamp the two parts together, but they do not expand their shanks to tightly fill the holes as do the Sonex supplied Cherry rivets and thus two parts can move relative to one another. Not what I like to see in an airplane. However, that bulge forming and clamping characteristic is ideal for riveting to fiberglass parts and avoids added stress and cracking out of holes in fiberglass. Since fiberglass does not have the strength to retain the rivet shanks from expanding, often see the heads of mandrels drawn all the way through the fiberglass. Also applicable to riveting somewhat softer hinge material to fiberglass minimizing distortion of the hinges around the rivets. Those are available in flush type as Zenith uses but which require a concave nose piece in puller, or conventional domed head. The heads of the flush type, after forming by the concave nose piece, are noticeably smaller than the domed heads with those of the 5/32" Avex flush rivets about same size as 1/8" Sonex domed rivets. The aluminum body of the Avex rivets may not be as strong as the SS body of of the Sonex - Cherry rivets, but is stronger than the fiberglass.
David A. Sonex TD
