Scott's Sonex 1629 - N629SX
Re: Scott's Sonex #1629 - Progress
Postby n502pd » Tue Mar 08, 2016 3:27 pm
Scott..great progress! I am enthused for you! I have just moved my wings to the airport, and will get the remaining there shortly.
Would you give me the source and part number for your wing root seal? You have probably done that a few times, but I have lost all references to it already. thanks much! :D
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby ScottM-Sonex1629 » Tue Mar 08, 2016 8:44 pm
Joe:
Thanks! Try this link, it's from Vans Aircraft parts section of their website. I purchased a quantity of (2) of the 12' long "wing root channel".
https://www.vansaircraft.com/cgi-bin/st ... ion=search
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby n502pd » Tue Mar 08, 2016 10:33 pm
Thanks for the quick reply Scott!
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby ScottM-Sonex1629 » Sat Mar 19, 2016 4:20 pm
Still making progress. Flaps and ailerons are installed and connected to the push rods. Not finished with rigging them to the plans, but close. As you can see from this photo I also need to finish the yellow vinyl stripes.
Gear leg fairings are done for all three legs, and installed on the nose and right main. The left main was giving us fits today so my son suggested we stop and go do something else.
Scott Meyer
ScottM-Sonex1629
Postby ScottM-Sonex1629 » Mon Mar 28, 2016 9:36 pm
Steadily crossing items off the to do punch list. Wheel pants and gear leg fairings completed!
Ailerons and flaps installed, flaps are rigged. Vinyl stripes and stars and bars done!
As an aside...I drove by the town of Mojave last week and saw the "Air and Spaceport", including the aircraft graveyard in the Mojave desert...pretty cool! I know we have a few Sonex/Waiex owners out in that area (Dana and Nick).
Scott Meyer
ScottM-Sonex1629
Postby ScottM-Sonex1629 » Sat Apr 09, 2016 10:30 pm
Final stages of painting the cowling and wheel pants. Everything is sanded, filled and ready to go into primer.
Mixing the primer...this stuff smells something fierce...must where breathing protection and painting suit.
Wheel pants covered in 2-coats of gray epoxy primer.
Cowling also finished in 2-coats of primer. Will let it cure overnight...and sand out any imperfections.
I really like painting...it just takes so long to get everything set up.
Scott Meyer
ScottM-Sonex1629
Postby 9GT » Sun Apr 10, 2016 10:41 am
That looks great Scott. I usually don't care for military paint schemes but your is an acception. It really looks good on the polished aluminum!
David Clifford
Howell & Gladwin, MI
RV-9A: Under Construction (I'm a repeat offender!)
RV-10: Built & Sold: Flying Since 2013 N959RV
Cozy MKIV: Built & Sold: Flying Since 2007 N656TE
9GT
Postby ScottM-Sonex1629 » Sun Apr 10, 2016 9:12 pm
Thanks David! I'm hoping the finished airplane turns out the way I planned. We will see once the painted cowling and wheel pants are installed.
I was able to spray the base coat of silver on today. The paint I'm using is a base coat/clear coat (automotive) system. I also plan to mix in some black and possibly red single stage urethane on the cowling.
Scott Meyer
ScottM-Sonex1629
Postby ScottM-Sonex1629 » Fri Apr 15, 2016 8:57 pm
Painting is all done. Clear coat was applied Wednesday night.
This morning I taped off the top of the cowling and sprayed the final gloss black (it's a single stage urethane paint). All in all it looks pretty good and can't wait to complete the reassembly at the hangar.
Had a few minutes on the way home from work to test fit the right main wheel pant.
Scott Meyer
ScottM-Sonex1629
Postby Sonex1517 » Fri Apr 15, 2016 11:00 pm
Looks great Scott! Ok, actually it looks incredible!
Chicagoland
N1517S
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Return to Photo Album
Users browsing this forum: LLR and 12 guests
