Hi Kip
Thanks for your interest...It may be possible to take up the excess length with the threaded rod ends at the ruddervator end, but because the interference between the AN4 bolts (at full left/right aileron deflection) and the top of the spar tunnel, I cannot get full forward stick travel. This means that the idler to mixer pushrod (which is supplied with an undrilled "tab" on the mixer end) is about 1.125" too long.
I hope the photos attached will clarify the situation. They depict the stick position when it contacts the spar tunnel in the full left and right positions.
BTW, I've emailed Kerry at Sonex for comment and eagerly await his advice too.
All the best
Rodger
- Full Left
- P4251551.jpg (72.18 KiB) Viewed 7592 times
- Full Right
- P4251552.jpg (72.96 KiB) Viewed 7592 times
- Recent Pic
- P3030619.jpg (54.41 KiB) Viewed 7592 times
