Stress risers in countersink holes?
Re: Stress risers in countersink holes?
Postby Bacon8tor » Thu Apr 07, 2016 9:43 pm
It must be my technique. I understand you get what you pay for. A high quality sharp bit should cut like butter. My uncaged bit was top quality yet cut no better that my $27 micro stop from AS. Your $24 micro stop works great. I don't get it. Looks like my next purchase will be from the Yardstore! :-)
John Bacon
Henderson, NV
Onex 164 N702JB Reserved
95% done.....
Bacon8tor
Postby kevinh » Thu Apr 07, 2016 9:47 pm
Yep. My old avery tools countersink makes nice repeatable holes - I just countersunk a zillion holes in my wing spar quite happily (went with the countersunk skin rivets).
kevinh
Postby kevinh » Thu Apr 07, 2016 9:48 pm
also - using a little bit of cutting fluid helps, and go slowish at the beginning.
kevinh
Postby Bacon8tor » Thu Apr 07, 2016 10:45 pm
Kevinh, using cutting fluid made a HUGE difference! I was reluctant to use because of the mess factor but well worth a few shop towels. I used just a drop or two of 3 in 1 multi-purpose household oil on a hole and it cut like the butter I was hoping for. The residual oil on my bit then worked well for about two or three more holes before adding another drop. Great advice. Thanks to everyone's input!
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby kevinh » Thu Apr 07, 2016 10:52 pm
woot!
kevinh
Postby 9GT » Fri Apr 08, 2016 10:11 am
That's called "chatter" and isn't good. You can avoid that by using high quality piloted countersinks in a good ball-bearing supported micro stop cage. Run the countersink a little slower and use a cutting lubricant such as Boelube. http://www.mscdirect.com/browse/tnpla/6 ... 0=61232534
David Clifford
Howell & Gladwin, MI
RV-9A: Under Construction (I'm a repeat offender!)
RV-10: Built & Sold: Flying Since 2013 N959RV
Cozy MKIV: Built & Sold: Flying Since 2007 N656TE
9GT
Postby Bacon8tor » Fri Apr 08, 2016 1:11 pm
Okay, so I understand what countersink "chatter" is. Also called "knife edge." And I understand they are "bad." But what makes them bad? What are the consequences of a "bad" countersink? Is it purely aesthetics? Of course I'm looking for any excuse not to buy new stock and countersink 20 new holes "correctly." (I love using "quotations"). Will the chattered countersink cause cracks in the aluminum in the future?
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby samiam » Fri Apr 08, 2016 1:50 pm
I'm no engineer or expert on the matter, but I see two obvious potential problems:
1. Stress risers
2. The rivet will not seat properly in the countersunk hole, thus leading to a weaker rivet.
Again, as I'm no expert, I can't speak as to whether or not you should redo them.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby gcm52 » Fri Apr 08, 2016 3:08 pm
One other thing that helped me: I found that the countersink stop would go out of whack a bit and give me the wrong depth after a few holes and I would have to readjust. I solved this by putting it in a drill press and getting the depth just right on a piece of scrap. Then you can countersink your actual work to the perfect depth over and over on the drill press, as long as you can get the work under the press.
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Postby 9GT » Fri Apr 08, 2016 3:28 pm
John,,,a couple reasons that chatter is not good for countersinks. It creates points of possible future stress cracks in the aluminum and and does not allow for 100% rivet seating and contact. Through the vibration that will happen during flight the joint will move ever so slight wearing the mating surface of the rivet and enlarging the rivet hole. You will eventually see a trail of dark blackish streak behind the rivet as it wears through the aluminum if its in the slipstream of the plane. These loose rivets are commonly called "smoking rivets" and obviously are a bad thing.
David Clifford
9GT
Users browsing this forum: Google [Bot] and 87 guests
