Ken,
Your latest numbers do not look that far off of the norm, but still surprised by the small main jet you are using. Mine would be running lean with that at WOT and any any needle. What color do you see on your plugs? Your CHTs are not a problem, and will continue to decrease as engine breaks in.
I give it full throttle on takeoff, and just off top of my head, see EGTs in the mid 1,200s and fuel flow of about 8-1/2 to 9 GPH. Leveling out with RPMs increasing while still at full throttle, fuel flow increases to about 10 GPH. My peak EGTs occur in cruise around 2,700 RPM, but that is strictly a function of my needle shape. Fuel flow at 2,850 RPM runs about 6 GPH when leaned to put EGTs about 1,300. Exact numbers vary with load and conditions.
If you have not already done so, would recommend you also join the Jabiru - CAMIt forum.
https://groups.yahoo.com/neo/groups/JabCamit/info <<<
There are a several very knowledgeable folks for this type of engine on that forum, many of them fellow Sonex drivers, who can provide additional information.
David A. CAMit 3300 in Sonex TD
