Spark Plug Wires
Spark Plug Wires
Postby rhw5548 » Sun Apr 03, 2016 6:33 pm
Has anyone purchased aftermarket spark plug wires from a performance shop and can recommend?
(for the lower plugs)
Plans Built SN #0243
MGL EFIS Electronics
Tri-Gear, Dual Controls
Todd's Canopy
Prince p-Tip Prop
Echo UAT (ASDB)
Jab 3300 A
FlyQ EFB
rhw5548
Re: Spark Plug Wires
Postby wlarson861 » Mon Apr 04, 2016 1:06 am
I replaced a couple with generic wires from O'Reilly Auto Parts, the originals got too close to the exhaust and burned the covering. They have worked fine so far.
Bill Larson
N861SX
wlarson861
Postby Fastcapy » Mon Apr 04, 2016 9:07 am
I used Accel Superstock wires for the bottom and top wires. The bottoms are carbon core, the tops have to be copper core to work with the Aerovee magnatrons.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby rhw5548 » Mon Apr 04, 2016 2:11 pm
Mike, do you have Part Numbers or they just generic. I'll also check out O'Reilly's.
Looked at the top Wires and they appear to be permanently attached ??
Thanks
Bob Wilson
SN #0243, AeroVee
Todd's Canopy
Prince p-Tip Prop
Echo UAT (ASDB)
Jab 3300 A
FlyQ EFB
rhw5548
Postby gammaxy » Mon Apr 04, 2016 2:48 pm
I'm also interested in Mike's top plug wires. My primary ignition creates some annoying interference when I'm listening to distant transmissions. I finally convinced myself that the noise is coming from the wires when I disconnected the p-leads from the magnetrons completely and still got the noise (I was concerned it might have been the p-leads since they are in a bundle with all the other wires coming through the firewall). Mike, have you run the stock wires to tell if the ignition noise changed with the new wires?
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby Fastcapy » Mon Apr 04, 2016 3:49 pm
I will have to go out to the hangar and get the part numbers as the top and bottom are different numbers.
No, they are not permanently attached. I will grab one of my 3 old magnetrons that failed and take pics of how to replace them.
Yes, I was chasing radio noise demons for a long time, which was the reason I decided to try them. These wires helped the noise immensely. I still get a little noise at full throttle but not nearly as bad as before. At lower RPM's I get very little, if any, noise now. Plus I think they look cool. I went with the yellow because that is what was in stock at the time and I didn't care much if they were yellow, red or blue...
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby nwawingman » Mon Apr 04, 2016 6:39 pm
I have found that the NGK spark have helped reduce the ignition noise to an acceptable level for me. I can still hear it when I do my mag check a little, but don't notice it in flight. Before it was very annoying.
Rick Wantz - Arkansas
Sonex 367 T/W AeroVee/Aeroinjector - Prince Elliptical Prop <361hrs
1st Flight 7/13 KOSHX3 Young EaglesX14
http://www.mykitlog.com/wingman
https://www.youtube.com/channel/UC2TNLK ... A63FvnPkNA
nwawingman
Postby radfordc » Mon Apr 04, 2016 9:29 pm
rhw5548 wrote:Has anyone purchased aftermarket spark plug wires from a performance shop and can recommend?
I bought Ford tractor wires on Ebay when I needed replacements. http://www.ebay.com/itm/like/2505706361 ... noapp=true
radfordc
Users browsing this forum: Google [Bot] and 80 guests
