1
Re: 1
Postby SonexEZ » Fri Apr 01, 2016 4:26 pm
maybe i have blow by due to only having 6 hrs on it ? the breather system was removed and was clean ,
SonexEZ
Re: 1
Postby kmwoody » Fri Apr 01, 2016 11:03 pm
After I rebuilt my Aerovee my oil pump leaked. I tried fixing it with just sealant, but it would not stop leaking. I ended up putting a gasket coated on both sides with a very thin coat of Permatex gray silicon. Didn't leak after that for 135 hours when I sold it.
Ken W
Sonex 959
CAMit 3300
kmwoody
1
Postby Sonex1517 » Sat Apr 02, 2016 8:22 am
Link to the post where the prop hub leak is discussed
http://www.sonexbuilders.net/viewtopic.php?f=7&t=1640&p=11818&hilit=Prop+hub+leak#p11818
Chicagoland
N1517S
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Oil Leaks
Postby Kalibr » Sun Jun 12, 2016 9:02 pm
Onex107 wrote:Why go to all that trouble. If you put a 1/2 inch adaptor on your torque wrench and use the open end/box end wrench at 90 degrees, you can torque those nuts behind the intake manifold without all the calculations.
i can confirm -- this works like a charm, at least for me it worked great
Kalibr
Users browsing this forum: No registered users and 89 guests
