Stress risers in countersink holes?
Postby Bacon8tor » Wed Mar 30, 2016 4:36 pm
Almost every hole I countersink in aluminum has little ridges in them. Are these like stress risers? Is this normal? I'm using a hand drill and have used two different countersinks with the same result. Every once in a while I get a smooth hole but it's rare. Is it poor technique? Is it okay to put flush rivets in there? If I try to smooth I'm afraid I'll only make the holes worse.
John Bacon
Henderson, NV
Onex 164 N702JB Reserved
95% done.....
Bacon8tor
Re: Stress risers in countersink holes?
Postby samiam » Wed Mar 30, 2016 4:40 pm
Are you using a microstop? If not, it's definitely worth the investment. They make beautiful countersunk holes, uniform, in much less time. Find 'em cheap on ebay or the yard store.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby Bacon8tor » Wed Mar 30, 2016 8:49 pm
Thanks, Samiam. I'll look into one of those countersinks.
My question now is can I go with the knife edged holes that I have now or should I start all over. This seems to be a fairly common problem.
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby kevinh » Wed Mar 30, 2016 10:07 pm
If you get a microstop cage (and go slowish with it) I bet it will fix the 'ridges' you describe (assuming you still have enough depth). Test on a piece of scrap first. Can you post a photo of a bad countersink? Also, I'm assuming you are using a piloted countersink (one sized for #30 or #40)?
kevinh
Postby Bacon8tor » Fri Apr 01, 2016 10:11 am
Thanks for the tip. I've tried to post pictures from my iPhone but the forum says they are too big. I don't know how to adjust.
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby Bryan Cotton » Fri Apr 01, 2016 11:43 am
John,
All my pictures are from the iphone. I mail them to myself and it lets me reduce the size to medium. Then I save the smaller pics to my phone to post. Clunky, yet it works.
I also think the microstop will cure your chatter. I set mine so I can bear down hard and that last bit of cutting smooths out.
Postby Bacon8tor » Fri Apr 01, 2016 11:46 am
Problem solved. GO SLOW. Drill speed that is. Everybody says that. I guess I should've learned to countersink before assembling the parts and posting this thread. I'll leave the post on so other newbies can learn from my mistakes.
But my other question still remains. Can I go with the "knife edged" countersinks or should I start over?
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby Bryan Cotton » Fri Apr 01, 2016 2:39 pm
John,
Knife edges on countersinks are generally bad. If the location was structurally critical I would replace or make a doubler. Check in with Sonex tech support.
Postby Bacon8tor » Thu Apr 07, 2016 9:15 pm
I bought the cheapest caged micro stop countersink from Aircraft Spruce and was disappointed with its performance.
In my whole ten hours of countersinking experience I'll give my takeaways and opinions which are just that. I am certainly not an expert.
The micro stop countersink was no faster than the simple bit in my hand drill. The micro stop also drifted and caused an oblong hole! I'm guessing this was somehow caused by not having a backing plate for the pilot.
I'm resigned to thinking countersinking is a long arduous task unlike drilling a hole. They are different animals. Slower speeds work better for countersinks. I get best production with a speed on my variable speed drill that is just a little faster than my eyes can follow the spinning bit. Drill a little then test with a rivet. Drill more and test again until you get the right size. Firm pressure while drilling and a little wobble until you get close to the correct size then as perpandicular as you can eyeball.
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby samiam » Thu Apr 07, 2016 9:18 pm
This is a very different experience than the one that I had. I bought the Yardstore's nylon tipped microstop, which was about $24. It made beautiful, easy, fast, and highly symmetrical countersinks. Couldn't have made the job easier.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Users browsing this forum: Google [Bot] and 82 guests
