by Onex107 » Thu Mar 31, 2016 12:24 pm
Don't ream that hole. It took two tries to get the first axle in. I heated the gear and froze the axle and as soon as the cold axle touched the hole, it cooled it and the hole contracted and the axle was not seated in the pocket on the back side.
The second time, after getting the axle back out of the gear leg, I heated the gear leg by sitting the gear upside down on the bench and sat my propane torch so the flame was just below the hole. When the gear leg is hot enough, the axle will slide right in. Don't freeze the axle. A few degrees increase in the aluminum makes up for the shrinkage in the frozen axle. Aluminum expands/shrinks four times as much, per degree, per inch, as steel. As the gear leg gets hot you can insert the axle by hand all the way. Then let it cool.
OneX 107
N2107X
