Fitting gear legs in mount
Postby Darick » Tue Mar 29, 2016 10:22 pm
So what's the trick? Take a few thousandths off the leg or hone out the mount? There is no way the legs will go in the mount without changing one or the other.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Fitting gear legs in mount
Postby ldmill » Tue Mar 29, 2016 10:26 pm
I spent some quality time with sandpaper and a file on the inside of the mount tube. I actually had some weld slag that was causing the issue.
Lorin Miller
ldmill
Postby Bryan Cotton » Tue Mar 29, 2016 10:41 pm
I may have scotch-brited the sockets. I definitely used oil. It was a nice tight fit. I bonded on the axles and both sides of the tail spring because the fit was not as awesome.
Postby Darick » Wed Mar 30, 2016 8:37 am
Thanks Bryan and Lorin. I was all set to continue with putting the legs on when I ran into this delay.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby DCASonex » Wed Mar 30, 2016 8:53 am
As I recall, found burrs, paint buildup. When all cleaned up, needed to wrap the gear legs with a a bit of thin stainless steel shim stock to get good tight fit. This was true of both top and bottom. Top end on my tail-dragger mount had short sections of heavier wall tubing at both ends which makes getting the shim stock all the way in a bit tricky. Think I put shim stock in first, then slid gear leg into that.
David a. Sonex TD #1327
Users browsing this forum: Google [Bot] and 67 guests
