Jacking up a Sonex
Re: Jacking up a Sonex
Postby kevinh » Sun Mar 27, 2016 11:36 am
Hi Peter, I'd totally go for one of those! (btw - thanks for the vents, they look awesome)
kevinh
Postby fastj22 » Sun Mar 27, 2016 7:12 pm
Love to have the plans.
Postby peter anson » Mon Mar 28, 2016 8:40 am
This only works with a "jacking point" such as the the inner axle extension on the Tracy O'Brien axles. Steve Woodham (Sonex 892) has suggested using a couple of hose clamps around the Sonex axle fitting to act as a jacking point but I'll draw up something a bit more substantial. I'll put a post here when I have tried the new arrangement and posted drawings.
peter anson
Postby sonex892. » Mon Mar 28, 2016 6:41 pm
peter anson wrote:Steve Woodham (Sonex 892) has suggested using a couple of hose clamps around the Sonex axle fitting to act as a jacking point but I'll draw up something a bit more substantial.
Hi Peter
I have never tried clamping hose clamps directly to the axles, it would probably damage the powder coating. I use the 2 hose clamps on the titanium rod. Just to be clear, I never trust this hose clamp arrangement to hold the aircraft up for any length of time whilst doing maintenance. I lift, remove wheel then chock immediately. It is what it is. Simple, cheap and light.
If I were to use your clever jacking method, on the standard Sonex axles. I'd probably either weld a small tab to the bottom of the axles. Or, utilize the 3/16" brake bolt somehow. I'm sure it wont be too difficult to come up with something.
This was my version 1 jacking point bracket, hose clamped to the titanium. I later discovered the hose clamps alone worked equally as well.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby peter anson » Mon Mar 28, 2016 8:27 pm
Oops, sorry about that Steve. Anything else you'd like me to misrepresent for you?
peter anson
Postby sonex892. » Tue Mar 29, 2016 4:32 pm
peter anson wrote:Oops, sorry about that Steve. Anything else you'd like me to misrepresent for you?
No worries Pete. Thanks for the offer, but there's nothing I can think of at the moment :lol:
Steve
Sonex kit 2010
sonex892.
Postby peter anson » Wed Apr 06, 2016 11:52 pm
Here's my final effort. I have changed the arrangement so that instead of pushing the handle down, it is lifted up. With the push down arrangement, maximum force on the lever was exerted horizontally, but it was difficult to find a reaction point. With the lift up arrangement, maximum force is reacted against the ground - much easier.
For more details and complete drawings visit my web site:
http://www.ansoneng.com/sample-page/products-summary/quick-lift-wheel-jack/
peter anson
Postby NWade » Thu Apr 07, 2016 1:23 am
Peter -
Awesome stuff! Count me in for 1 or 2 of these, if you get some made for sale. I have stock axles; but I'm not done building so I can afford to be patient and either work out a hardpoint solution later, or take advantage of your fine engineering if you come up with something. :D
--Noel
NWade
Postby peter anson » Thu Apr 07, 2016 2:17 am
Hi Noel,
Thanks. I wouldn't use two of these at once. You might notice that it's pretty skinny. Relies on the other wheel for lateral stability. Have drawn a hard-point but it's amazing how many different ways things can interfere with each other so I need to try it first. Probably in a couple of weeks.
Sonex 894
peter anson
Postby NWade » Thu Apr 07, 2016 1:01 pm
peter anson wrote:Hi Noel,
Thanks, Peter - I wasn't intending to! I just lose things, so I figured buying two will help. :roll:
And on a more practical note: it would let me keep one in my hangar and one in the baggage compartment of the Sonex, "just in case"...
Take care,
--Noel
NWade
