samiam wrote:1. Only the tail has been started. Everything else is untouched. I already finished my own tail, so I wouldn't be relying on anyone else's construction quality.
samiam wrote:2. I definitely want to build. That is the dream for me. I know that it will take years and be very frustrating at times, but it is still the dream.
At this point I am definitely leaning towards picking up this used kit. It will definitely take longer without the matched hole parts, but I will likely be ordering at least some of them from Sonex to help the build.
samiam wrote:The kit includes the hardware as well as some tools and clecos, so it seems to be a pretty good deal to me. I've decided to go for it. Moving truck booked for next Thursday if all works out!
Thanks again for everyone's help and advice, it is much appreciated
fastj22 wrote:The big ones are the spar caps. Sonex won't replace those without you sending back proof you destroyed them. So just make sure you get those. Also a full set of plans. Not sure they will send you replacement sheets.
Also don't get too overwhelmed with the amount of stuff. When your run out of stuff to install, you should have an airplane!
Users browsing this forum: No registered users and 64 guests
