Kalibr wrote:As I've been enjoying my new to me Onex, I've come to realize one peculiarity of Aerovee engine (or any other engine spinning its prop counterclockwise) that may catch up to a pilot not used to flying behind those type of engines. Yes, on takeoff/climbout or other high power/lower speed maneuvers you need to be on the left rudder instead of the right one in a more conventional airplane. That's very obvious and takes very little time to get used to.
One situation is the notoriously deadly base to final turn -- where the natural instinct of pointing the nose towards the runway with left rudder leads to a skidding turn, which combined with slow speed and either attempt to extend the glide or with wind sheer, may result in stalling/spinning into the ground. In this situation, the left yawing tendency with reduction of power of an airplane with a counterclockwise spinning prop aggravates the already potentially dangerous setup.
Users browsing this forum: No registered users and 33 guests
