Waiex tail hockey stick - drawing revision
Re: Waiex tail hockey stick - drawing revision
Postby Bryan Cotton » Wed Sep 11, 2013 5:52 pm
Thanks Kip. I did see his tool on the net last night. Too bad it is out of circulation! Did anybody bend to the new line with it?
Postby N111YX » Wed Sep 11, 2013 6:59 pm
Bryan, I'd guess that the tool was "lost" at least two years before the "new bend" issue came about... 8-)
Bryan Cotton wrote:Thanks Kip. I did see his tool on the net last night. Too bad it is out of circulation! Did anybody bend to the new line with it?
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Bryan Cotton » Sat Sep 14, 2013 10:18 pm
First,
Thanks Kevin Conklin for posting your frustrations. They made me think and that helped. Observations:
1) the 1" half-hole worked good. I never bothered with the 1.5" half hole. See my Waiex 191 thread in the photo section if you have not yet.
2) you need a 1" solid steel bar. My 1" tube with the broomstick handle just crushed. It is a lot of force.
3) I think a hydraulic press would be better than an arbor press. It takes a lot of force.
Postby John Usher » Mon Mar 21, 2016 9:00 pm
Hi Bryan,
I'm about to bend my YX-B hockey sticks and looked for your photos but the post says your pic was "deleted due to quota". May I trouble you (or anyone else that has any) to post your pics of the way you bent your hockey sticks?
Thanks in advance!
John U.
John Usher
Sold all my toys...
John Usher
Postby Bryan Cotton » Mon Mar 21, 2016 11:11 pm
John:
Check near the bottom of my page 25:
viewtopic.php?f=39&t=578&start=240
Another helpful tip: try not to drill your finger! I just did the first time ever and found nothing about the experience that I would recommend. This is not a hockey stick specific tip.
Postby kevinh » Tue Mar 22, 2016 12:34 am
Here's my knock-off of Bryan's jig. It worked great. Easy cheezy, just stuck it in the press and squeezed...
kevinh
Postby John Usher » Tue Mar 22, 2016 10:18 am
Thanks Bryan and Kevin for the pics! Bryan, you're correct, the human finger doesn't make a very good drill stop! Hope it heals fast! OUCH!
John Usher
Sold all my toys...
John Usher
Postby LarryEWaiex121 » Tue Mar 22, 2016 12:36 pm
Just a suggestion to those who've not already pressed their hockey sticks.
A wrist pin out of a diesel engine, will give a pristine surface to apply to the unbent stick.
No flexing and with careful press operation gives a really nice finish without inducing any imperfections in the radius of the sticks.
I often remember John Monnett's mantra. Your not building a watch! I still feel good about things done pretty close to right.
Larry
Waiex121YX, 458hrs, starting fifth season with new Camit 3300. Happy, happy!
LarryEWaiex121
Postby Bryan Cotton » Tue Mar 22, 2016 1:25 pm
I bought a 1" bolt from Menards. Not as good of a surface finish as a wristpin but sufficient.
Postby LarryEWaiex121 » Tue Mar 22, 2016 2:46 pm
Bryan,
Your never going to be qualified to work on a gov't project if you can't figure how to expend more than 47 cents on a bolt!
Mine came out of the dust bin here at work (Kubota and New Holland sales).
Sometimes its just more fun to have an elegant solution to simple problem. :)
Larry
LarryEWaiex121
Return to Waiex
