ScottM-Sonex1629 wrote:Are you sure you're applying enough polish and thoroughly spreading it around in small sections, then removing it with the machine/wool pads before moving to next section?
Scott; I think you are correct, I was breaking the skin into 1/4 sections, if that makes sense, and trying to cover too large an area. How did you get the stuff to come off with the pads? I keep the same speed and never got the skins to be free of polish residue, albeit small black specks everywhere that came off with the mineral spirits.
Bryan Cotton wrote:Show that metal no mercy with the F9.
Bryan; I was always afraid of overheating the metal! I'll get those skins back on the table and try smaller sections and a lot more pressure and more time in smaller area's
The compounding pad I use. Do you have to remove the markings from the metal before F9?
Macro photo, the grain is starting to close up some from the first passes, should be smoother?
