by mike.smith » Fri Mar 18, 2016 8:27 pm
Hi, Ed:
I've built my AeroVee 3 times (stories for another day). Using the recommended Permatex sealant on the case halves has yielded zero leaks for me. Silicone is definitely bad news and won't let the case halves mate properly. That means the required crank bearing "crush" will not be attained, which will wear out the bearings and the crank journals.
As for the end play I'd certainly talk to Sonex before you machine the crank. I've had two cranks and both required 3 or 4 shims. I've not heard of your situation in another AeroVee, but that doesn't mean it hasn't happened.
Hard lessons learned for me on the shims and rear seal:
- When you set the shims you will be doing it without the RTV to seal the end of the crank with the 8 pins. That RTV will add thickness and cause more end play than you figured when it was dry. So adjust your shims so you get the minimum play: around .003, rather than the high end of .006. it will take a lot of frustrating trial and error, but it's worth it. When you install the RTV and torque the gland nut, you'll likely find your .003 has turned into .004 or .005.
- Install the RTV EXACTLY per the instructions. Yes, there are instructions. Install the RTV and put on the flywheel and gland nut to finger-tight. Wait 1 hour, THEN tighten and torque. If you don't wait, most of the RTV will squeeze out and you'll have a leak almost right away. Wait at least 24 hours before running the engine or adding fluids.
- Install the rear seal just slightly below the surface of the back of the case, rather than flush or proud.
- Make sure you put a little white lithium grease on the rear seal before you put on the flywheel. If you don't then you risk tearing the seal as soon as the engine is turned over.
These are things I did not do in the past and regretted it. Learn from my mistakes!
