Prince prop question
Anything related to props
Postby Johns » Sun Mar 13, 2016 3:56 pm
Anyone with a force one hub go from a wood Sensenich wood prop to a carbon p-tip Prince prop. Would this be a straight forward swap or are there complications?
John
Johns
Re: Prince prop question
Postby SonexEZ » Sun Mar 13, 2016 4:28 pm
Johns wrote:Anyone with a force one hub go from a wood Sensenich wood prop to a carbon p-tip Prince prop. Would this be a straight forward swap or are there complications?
John
I had a prince P tip it went back 3 x for repairs , the 3rd time i was told it cant be repaired and to get a new prop , I ordered a sensenich and it works fine , Good luck if you choose to go to prince
SonexEZ
Postby Sonex1517 » Sun Mar 13, 2016 6:13 pm
I love my Prince P tip, and have found Lonnie Prince to be a great guy to deal with.
My prop was easy to install, used the hardware supplied with my AeroVee and some AN bolts.
Can't say I have experience with other props or switching them, but I love the propeller I bought.
Chicagoland
Postby SonexEZ » Sun Mar 13, 2016 6:22 pm
Sonex1517 wrote:I love my Prince P tip, and have found Lonnie Prince to be a great guy to deal with.
Chicagoland
wait till it goes bad and you will see how good he is helping !!
SonexEZ
Postby Sonex1517 » Sun Mar 13, 2016 6:39 pm
Chicagoland
Hmmm. Actually when the first one didn't meet expectations, he replaced it. For free. Even shipped it to me.
I stand by my recommendation. Great guy, great product, fantastic customer service.
Sorry for hijacking the original thread....
Chicagoland
Postby MichaelFarley56 » Sun Mar 13, 2016 8:07 pm
Let's not get off topic here guys. Personal feelings of bitterness doesn't help John.
John, if I were to guess I'd say it's a direct replacement but your best answer would come from Lonnie himself. Give him a call and ask; he's built thousands of props and can answer your question. I'm sure that, even if a small modification would be needed, he could easily accommodate it.
Postby rizzz » Sun Mar 13, 2016 8:16 pm
John
I have a prince P-Tip 54x48 on my 2400cc VW powered Sonex, and I have the Force One Prop hub.
Just tell Lonnie Prince what you have and he'll make it accordingly.
This is my first prop so I have no experience with the Sensenich.
However, my hangar buddies have the Sensenich props on their Sonex's, it looks like it would be just a straight swap apart from the bolts, the Sensenich props appear to be much thicker. The prince prop will require shorter bolts.
Postby WaiexN143NM » Mon Mar 14, 2016 12:30 am
Hi all,
Just wanted two throw my 2 cents in to this thread. Thanks Mike F for interceding, although when u referred to John, I think you really wanted to refer to sonexez (guy). John was the original poster. Sonexez we'ved all posted and helped you out on the used sonex you bought, glad to see you're getting things sorted out and flying, the prop you had (Prince) not sure of the history and use behind this prop. But please cut Lonnie Prince some slack. He is a top notch guy. And a great supporter of the sonex airplane community. We had a small problem with our carbon p-tip prop, he sent us a new one the next day, we used the box to send the old one back. Very pleasant and easy to deal with. Sorry you were not pleased but sending the prop back 3 times? At some point he will need to start charging for his time to repair it.
I've never been to crossville, hopefully someday, but doesn't Lonnie come and give a propeller seminar? And donate a new prop as a raffle prize? Gee many others have posted about good experience with Lonnie. Sorry you don't feel the same. We've all had experiences with different aviation sources, usually a civil call to straighten things out works. Only once a civil call resulted in hostility back.
Thanks Mike F. For letting me rant, abit slightly off topic.
Postby peter anson » Mon Mar 14, 2016 8:33 am
My Prince prop developed a fault. Can't think how it happened. Do you think Lonnie would cover warranty?
https://www.dropbox.com/s/t9yyb55xjvsvs1z/20150205_163045.jpg?dl=0
Sonex 894
peter anson
Postby Darick » Mon Mar 14, 2016 9:08 am
Well I wouldn't have called that a fault. Unless you are talking about the prop version of the San Andreas fault.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Return to Propellers
