Let's say your torque wrench is 12 inches long from the center of the square drive to the center of the handle.
Been around a long time but have never seen a torque wrench that looks anything like that. Doesn't seem like something with those dimensions would be very easy to work with. Obviously a typo but Mr Norris never answered my question off line-"What is wrong with using silk thread on case halves?" Easy answer to say it isn't in the manual. There are numerous things that aren't in the manual that should be. Just one example is that there is no mention of how to properly install circlips on wrist pins. If you looked at the package the replacement clips came in there is a little instruction sheet saying that if you don' put the sharp edge outward, the clips can work themselves out. After having several instances of that happening, one could reasonably think that a note to the manual could be added to that effect. And if orientation of circlips wasn't spelled in the manual to begin with(which it wasn't), how many people were there that didn't know there was a right way to install them got it wrong? Fifty/fifty chance on 8 clips-not good odds when you are talking about aircraft engines.
I never once said it was Sonex's fault I got a bad case-I only pointed out my problems to help others look closely at certain things I encountered. The lack of quality control lies with the foundry and shop that did the machining. I never once said the flawed crankshaft I got was Sonex's fault-I sent an email to Kerry to tell him what I found and he said and I quote, "good catch". I tried to share what I found to help others but only found that Sonex does not accept constructive criticism of any sort.
Fact is I never had a case leak in that location until I removed the bolt that holds the brace for the intake. I have attached a link to a video I posted 3 years ago that demonstrates just a little of the care I took assembling my AeroVee. There are many other youtube videos that I posted to demonstrate how I did some things during my build-not saying they were right but they worked for me.
https://www.youtube.com/watch?v=UVdycOvy84gLoren Sievila
Onex 33
In the process of removing AeroVee and installing 2200CC Camit.
