peter anson wrote:The MGL instructions for the RDAC suggest using the same connection as for a Bendix magneto - connect from the low tension side of one of the coils to the RDAC tacho input via a 10K resistor and remove the ballast resistor link. I actually used a 12K resistor, presumably because that was what I had available at the time. It works perfectly, completely reliable. I have checked it against an optical tacho and it is accurate to the resolution of the optical tacho.
Sonex 894
vwglenn wrote:peter anson wrote:The MGL instructions for the RDAC suggest using the same connection as for a Bendix magneto - connect from the low tension side of one of the coils to the RDAC tacho input via a 10K resistor and remove the ballast resistor link. I actually used a 12K resistor, presumably because that was what I had available at the time. It works perfectly, completely reliable. I have checked it against an optical tacho and it is accurate to the resolution of the optical tacho.
Sonex 894
So essentially you just installed an in-line 12k resistor on the wire and are having success? Don't remember reading about that in the manual but I probably blew over the Bendix mag part.
