by SonexN76ET » Mon Feb 22, 2016 4:18 pm
I followed mostly the same process as Ryan. I built the engine to include mounting the accessory plate and the alternator and electronic ignition, then just rolled the plane up to the engine on a table with wheels and plugged the engine right into the engine mount, all by myself. Easy! Keeping the accessory plate on prevents having to mess with the electronics from behind with the engine mounted. So, I know both methods work, I just prefer not to have to mount the stator and electronic ignition in the close quarters behind the engine mount.
Jake
Sarasota, Florida
