N111YX wrote:Does anyone know the temp/humidity that Jeff experienced on the descent? Was he at idle?
...I was cruising at 8,500 ft MSL and had the airport in sight approximately 30 miles out. At about 10 miles out, I reduced power from cruise power to a descent power setting, and began my gradual descent into MEZ. After 2 or 3 minutes of descending, at about 5,000 ft, the engine suddenly lost power. It continued to run, but was not producing any significant power. I attempted to restore power by adjusting the throttle, mixture, and mag switches, but after 30 seconds or so, the engine died completely. I was able to restart it once, but it barely ran, and died for good after 10 seconds or so...
MichaelFarley56 wrote:I've always wondered if one possible reason why there's no carb ice issues is that we draw air from inside the cowling where the air is warmer rather than having some kind of ram air scoop to draw in cold air.
142YX wrote:MichaelFarley56 wrote:I've always wondered if one possible reason why there's no carb ice issues is that we draw air from inside the cowling where the air is warmer rather than having some kind of ram air scoop to draw in cold air.
I was thinking the exact same thing. The aerocarb will not even work with a ram air induction.
Andy Walker wrote:
Several people have added NACA ducts to their cowl leading to an enclosed chamber for the air filter. Not ram air, but certainly cold(er) air. I have not heard of these setups having problems either. Maybe just lucky so far, though.
Users browsing this forum: autopro and 68 guests
