lgsievila wrote:Has anyone put a Jab or Camit 2200 in a Onex. I know of one in Florida.
Loren
DCASonex wrote:Do not know if it would be much different with a 2200 engine, but on my 3300 installation, with air filter directly on the Bing Carb, it takes in air that has been heated by passing through the engine's cooling fins, and thus is much like flying with carb heat on all the time. Have carb temperature monitor and the electric heating option on the Bing, but have seen no real need for the electric heat. Would be a bit more power if taking in cold outside air, but at loss of simplicity.
David A. Sonex TD, CAMit 3300.
peter anson wrote:Hi Loren, if you are going with the Camit 2200, can I suggest you stick with the Bing Carburettor. They work really well. Sure, you have to make a carb heat system, but if you are capable of making the engine mount, a heat system is easy. I wasn't aware that there was such a thing as a "Sonex burp" until I read about it here.
Sonex 894
Users browsing this forum: No registered users and 33 guests
