by Sonex1243 » Thu Feb 18, 2016 11:11 am
Hi Peter, I tried an original picture , but, it was kicked back. I normally use the postimage.org site. Is there a better way to post larger pictures, like resizing the original somehow?
Bryan, I initially thought that bottom line was square and drew it as such. Caught it on the 2nd+ measurement verifications since it wouldn't line up at the trailing edge mark leading me to believe it was wrong! Re-marked line and cut to line up at trailing edge.
As a sanity check, I also set the skin across the right wing hinge / spar (fiberglass tip not fit yet) and it tapers right / aligns with top skin, but, I will need to do a little more trimming to get that angle and bottom edge to line up with the rear spar taper and lower skin line before fitting the tip rib.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
