by caymancraig » Sat Feb 13, 2016 12:49 pm
My voltage runs from 12.4 to 11.8 during flight. The alternator is charging. Is this normal voltage? I ran the battery COMPLETELY dead twice and it seemed to recharge okay. Regular Odessy as recommended by Sonex.
Next up is oil pressure. I polished the two plungers and it seems to be settling in. 74lbs at startup, 38 lbs at 180 degrees, and 30 lbs at 200 degrees. I added two washers under the rear spring and that raised it to the current 30 lbs. My CHT and EGT's are staying below the yellow range if I careful with climb. I understand the CHT and EGT's will improve with time. (only 4 flights right now).
Guess I'm looking for some reinforcement right now, lol
Thanks all,
Craig Mock
Craig Mock
Waiex - N239YX
Tri-gear, turbo, Dynon panel
Naples, Fl
