Ken's Sonex 1243
Re: Ken's Sonex 1243
Postby Bryan Cotton » Sat Feb 06, 2016 11:15 pm
Looks good Ken!
Postby Sonex1243 » Sat Feb 06, 2016 11:59 pm
Thanks Bryan. Got everything stored and on to the next phase of flaps and ailerons. The angles and cut outs look a little intimidating..
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Ken's Sonex 1243
Postby Sonex1517 » Sun Feb 07, 2016 10:04 am
Excellent! A big milestone! Congrats
Chicagoland
Postby Bryan Cotton » Sun Feb 07, 2016 10:12 am
Ken,
The flaps and ailerons are pretty easy and fun to build. I would not worry about the cuts etc.
Postby Rynoth » Sun Feb 07, 2016 10:37 am
It's real easy to overthink the angled cuts on the aileron and flap skins. I even tried to make them with my miter saw using trigonometry to dial in the various angles. Don't do this.
Just mark each measurement as it is on the plans (paying attention to which side is "up" and which side is "flat"), draw a line between the marks, and use a cutoff wheel or snips to make the cuts.
If you want to give yourself some room to breathe, make the angled cuts first, before cutting the far side to appropriate length. That way if you muck up the angled cuts, you can just move down the aileron an inch and try it again. Just draw your line for the straight cut, use that line as reference to make the angled marks, and cut the angle side first.
Postby Sonex1243 » Tue Feb 09, 2016 11:33 pm
You guys were right!
I managed to get the flap angles cut on both and then trimmed to final length. I had made the drive horns and hinges awhile back, so, they should go together as pairs pretty quick.
Left flap marked and right flap cut, trimmed and marked for pilot drilling
Fitting right flap drive horn
Both flaps trimmed and cut to final length with rib / drive horn fitting in work
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Fri Feb 12, 2016 11:06 pm
Flaps ready for deburring and the dreaded polishing. I think I'll get the ailerons ready and polish everything then.
Right flap piloted
Left flap piloting in work
Flaps piloted
Ready for deburring
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Thu Feb 18, 2016 7:06 pm
Work continues with the aileron counterbalances. The drive horns and hinges were done a while ago.
my demented way of aligning and pilot drilling the ribs to the arms
ready for riveting
finished
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Fri Feb 19, 2016 9:19 pm
After some slight confusion on an aileron skin dimension, I finished cutting the skins and made the other cut outs for the drive horn and counterbalance assembly. Started marking the rib locations and only have the right one down to marking the rivets.
skins cut and filed
tip cutouts done
right skin rib and rivet locations in work
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Wed Feb 24, 2016 12:07 am
Didn't like my first round of markings, so, I erased them and re-drew. Much better this time. Got the right aileron skin piloted and have the ribs and counterbalance assy in place for piloting.
Skin piloted and ready to pilot the ribs etc.
A rare glimpse of the dungeon, was a warm day last week and had the door open. Natural light for once was a treat. Now, to actually do some cleaning and rearranging some day..
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Photo Album
Users browsing this forum: Google Adsense [Bot] and 26 guests
