ededoad wrote: The only sticker I have is the warning to passengers.
ededoad wrote:The propeller is a 60X56. I have 6X5 inch wheels and 15X6 tires to keep the prop out of the ground. With 96 lbs of fuel and my 200 lbs The CG is at 64.3 inches or 21% MAC. Battery is behind the seat an 4.3 lb weight under the stabilizer. The only sticker I have is the warning to passengers.
rizzz wrote:ededoad wrote: The only sticker I have is the warning to passengers.
Something like:
"Warning, this Sonex is equipped with a certified aircraft engine"
:mrgreen:
ededoad wrote:Empty weight is 751 Lb. gross will be determined by flight testing. I told the FAA inspector between 1230 and 1250.
After 1 hour I will probably go for the 1250.
It is a little heavier than I wanted but I painted it inside and out and put too much paint on the out. If I did it again I would use wrap film .
fastj22 wrote:Sounds like the Conex is right there with the Corvair Cleanexs
Waiex 49 wrote:Pretty much any larger engine Sonex is going to weigh more than a VW powered Sonex. No rocket science there.
Users browsing this forum: Bing [Bot] and 20 guests
