by 13brv3 » Sat Jan 30, 2016 10:19 pm
Mine didn't match either. I had to drill a couple extra holes, and not use some of the ones that were there.
The upper right longeron holes on my machined angle part had a problem as well. Check the front holes against the glare shield holes to see if they match up. I just used the glare shield to drill new holes as needed.
Finally, the F08-14 and F08-02 parts fit together for the seat support on the rear of the floor. There are two holes that join the angles on the side with the main angle. On my machine parts, I riveted them together as shown, and found out that the main angle sits about 1/8" off the floor skin instead of flush. I had to take them apart an drill new holes to mount the main angle lower, against the skin.
I told Sonex about the last two, but I don't think I mentioned the first one. FWIW, my kit# is 0191. Of course even with a few errors, the machine parts are just great!
Cheers,
Rusty
Rusty
Fixed wing, gyroplane, A&P
