New user and question about cylinder Temp
Postby Loiret39 » Wed Jan 27, 2016 7:32 am
hi all,
I'm a french private builder of a JPM Loiret and i use an Aerovee engine on my plane with a lot of pleasure.
I build a web site of my construction at this adress: http://ulmloiret39.olympe.in/acceuil2.html
I have a question about the position of the cylinder probe: where do you place it? under the plug or on the cylinder fin?
Thank's for your answer
Regards
Ansré
Loiret39
Re: New user and question about cylinder Temp
Postby jjbardell » Wed Jan 27, 2016 8:05 am
Here is a link to the manual. It's has the exact location. Hope this helps.
http://www.aeroconversions.com/support/ ... Manual.pdf
N83LJ - Sonex #0864 (SOLD)
jjbardell
Postby Loiret39 » Wed Jan 27, 2016 9:26 am
Thank's jjbardell for this link, but i don't read anything on about the position of the CHT probe...
André
Loiret39
Postby marsolgp » Wed Jan 27, 2016 9:45 am
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Postby Loiret39 » Wed Jan 27, 2016 10:07 am
Thank's a lot. So my probe is under the sparkplug. Do you think there's a temperature difference with the Aerovee montage?
I have about 370° on the 3 cylinder at 2800 tr/mn!
Loiret39
Postby marsolgp » Wed Jan 27, 2016 1:34 pm
Like it says in the above install instructions, this location gives similar readings to the 'under spark plug' location..... The advantage is, similar reading without having to disturb probe every time you remove and install spark plugs.
As for 370 degrees at 2800 rpm, that looks good to me.
G. Marsolais
marsolgp
Postby Loiret39 » Thu Jan 28, 2016 6:18 am
Thank's a lot for your answer
Regards
André
Loiret39
Postby nwyooper » Thu Jan 28, 2016 11:48 am
Hi Andre,
You don't say what the outside air temperature is to go along with your CHT of 370 degrees F. If that was on a really cold day you might get close to high normal temps on a warm day. For your reference my CHT's are 325, 315, 327, 323 at 3100 rpms. Outside air temperature was 73 degrees and indicated air speed was 118 mph. I am not familiar with your aircraft but airspeed and proper baffling obviously will affect your CHTs.
Loren
Onex 33
AeroVee with Rotec MK II TBI
Dynon Skyview
nwyooper
Users browsing this forum: No registered users and 29 guests
