Wing attachment block SNX-W11-03 attach pin hole
Postby Sonex1517 » Thu Feb 16, 2012 4:25 pm
agreed Andy - I borrowed a drill setup with an attachment to make the drill bit sit at 90 degrees - but it requires a relatively large flat area and is not always applicable without additional cheaters or a jig....see attached.
I am still curious - after completing both main spars, then disassembling the ribs off of them, that is the point where I join the two spars and drill up? Everything I read makes me believe that is correct...
Re: Wing attachment block SNX-W11-03 attach pin hole
Postby MichaelFarley56 » Thu Feb 16, 2012 6:56 pm
Once the spars are assembled I can't think of any reason why you can't join them and drill. I did that before I started fitting ribs.
