Rynoth wrote:Well, it appears I just solved my rpm indication problem. I switched to the other lead from the alternator, now it works great. The wires aren't labeled, so it if doesn't work on one, try the other.
13brv3 wrote:
Good to hear Ryan. Thanks also for the panel picture. When I draw out the screen sizes on paper, the Discovery sure looks small, but it looks a lot bigger in your picture. For size comparison, which iPad is that?
Rusty
Rynoth wrote:It's an iPad mini, 2nd Generation I think. I couldn't fit anything larger than the discovery into an unmodified Waiex panel due to the tilt of the panel and the lower crossbar (depth becomes an issue.) I don't believe the Onex has this issue since the panel is vertical. The iEfis is amazingly light and actually not very deep either.
If you can fit an Explorer I'd say go for it. The size of the Discovery is just large enough to be able to navigate the menus using the touchscreen, it couldn't be much smaller before you might tap the wrong item with large fingers. It works great but a tad bigger wouldn't hurt. It's a lot of information on one screen (which is what makes it neat!)
