nosky2high wrote:Additional questions, once all holes are drilled, deburred, and surface cleaned; should I dimple before or after applying the self etching primer
nosky2high wrote:Okay, Started out by assembling the stabilator substructure to get familiar with the parts and plans.
Looks like pilot drilling the forward spars "hockey sticks" to the forward spar channel is the first order of business.
Two issues came up in the initial assembly of the substructure.
1. The predriled -06 clip did not match up to the predriled leading edge rib, do I just center up as best as I can and drill them together in the drill press?
2. The tip rib -08 didn't slide over the forward stabilator spar -02, looks like a simple trim of the spar flange will do, just making sure that it's normal to be trimming "match holed" parts this early in the project.
I'm sure I'll have lots more questions. Be patient, I learn quick.
Anthony
Users browsing this forum: No registered users and 21 guests
