mike.smith wrote:Unless you're running fuel injection with GAMI injectors you are going to have a hard time tuning cylinders to match.
MichaelFarley56 wrote:mike.smith wrote:Unless you're running fuel injection with GAMI injectors you are going to have a hard time tuning cylinders to match.
You're absolutely right Mike, although there is one more option that really balances EGT and CHTs; add the turbo! Adding forced induction virtually eliminates any intake system limitations and I normally see my CHT spread within 5 degrees and EGT spread within 10-15 degrees between all 4 cylinders.
And I like your lottery idea!
MichaelFarley56 wrote:You're absolutely right Mike, although there is one more option that really balances EGT and CHTs; add the turbo! Adding forced induction virtually eliminates any intake system limitations and I normally see my CHT spread within 5 degrees and EGT spread within 10-15 degrees between all 4 cylinders.
