by SonexN76ET » Tue Jan 12, 2016 8:44 pm
Josh,
I will second everything that Mike and John just posted. I would also like to add a couple of more thoughts on the subject.
First, there have been too many instances where the pilot attempted to return to the airport at low altitude after loosing engine power for whatever reason. They did not make it. On the other hand, a few Sonex pilots in recent accidents have maintained control and landed straight ahead and walked away with minor or no injuries, including a couple who landed in the tree tops.
A Sonex stalls at less than 40 MPH. If you loose an engine, that should be no worse than running your four wheeler off a trail at 40 mph, as long as you don't stall and spin. So, do not attempt the impossible turn! I am thinking that because the aircraft is so manuverable, pilots think that they can cheat physics and make a low altitude turn to return to the runway. Train yourself not to give into this temptation!
The second point is there are very few, if any, instances of a catastrophic engine failure in the Sonex accidents. Some are due to maintenance errors, some to improperly repaired engines occurring after a propeller strike. Others are for indeterminate reasons. Whatever the reason, this means that you have to pay attention to detail when you install and maintain your engine. Make sure your engine is getting proper cooling air. Make sure your fuel lines are properly routed and secured. Make sure your engine controls are robust and properly secured, safety'd and routed. Make sure your induction system is properly set up and secure and safety'd. Make sure you fully understand all of the systems and how they work and how to inspect them.
There are no smoking guns in any of the accidents that I can find. Try to learn from the mistakes of others. Try to build in as much safety as you can into your aircraft (styrofoam under the seatpan, seat belts padded with racing should and waist pads, energy aborbing foam in your seat cushions, angle of attack indicator, etc.).
Practice ultra safe flight practices when you are in Phase One and after any modifications. These practices would include using an airport with long runways, flying high, remaining within gliding distance of a suitable landing area, never flying with less than an hour of fuel reserve, only flying in good weather in daylight, etc. Also, make sure you go to the Sonex transition flight training program and maintain your pilot education throughout your flying career.
I wish you the best of luck in your decision and your aircraft building!
Jake
Sarasota, Florida
