Nose Gear
Nose Gear
Postby Concorde » Mon Jan 11, 2016 12:31 pm
My question is regarding the bolt and the nut that goes in the drive horn (SNX-L02).
Plan calls for AN5-32 bolt (drilled) and AN363-524 (lock nut with nylon insert) and not the castle nut as I was expecting. Is this correct and wouldn't there be an issue with nylon insert and the heat ?
Ben
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Re: Nose Gear
Postby Sonex1462 » Mon Jan 11, 2016 10:35 pm
Hi Ben,
The AN363 nuts are all metal stop nuts not the nylon inserts.
http://www.aircraftspruce.com/catalog/hapages/an363.php
"The AN363 all-metal stop nuts are designed for use in high temp installations (up to 450°F). Fabricated from cadmium plated per specification QQ-P-416C."
The AN365 are with the nylon inserts.
John Stewart
Sonex 1462
Sonex1462
Re: Nose Gear
Postby Concorde » Tue Jan 12, 2016 8:54 am
Hi Stewart,
I guess Aircraft spruce sent me the wrong nut no big deal . How about the bolt, is it suppose to be drilled ?
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Users browsing this forum: No registered users and 66 guests
