surfly wrote: What sealer would you recommend for the threads?
surfly wrote: I am still unconvinced that the inside of the case halves were not cut too deep during machining thereby cutting off the inside end of the inserts which are normally blind as they are in in automotive use.
surfly wrote: I am surprised that other builders have not brought this subject forward before now.
surfly wrote:I believe that I have not made myself perfectly clear. My only problem is that my case halves came with inserts that ARE NOT blind. Looking into all of them it is a clear open thread all the way from the outside to the inside of the case halves. I believe that the inner part of the inserts were completely ground off during machining leaving them completely open.
How many other case halves were machined this way leaving the inserts completely open from the interior to the exterior of case halve? Is this normal?
Surfly
Surfly
Users browsing this forum: autopro and 58 guests
