by Klimek » Tue Jan 05, 2016 11:43 am
Surfly,
Being a retired VW tech, this is what I did.
The longest studs go on the bottom 4 locations on each side. The next longest on the top outer locations. The shortest studs screw into the two
inner inserts. The intake manifold is located here and these studs are the shortest of the 3 lengths. I installed with BLUE Loctite and just snug them down.
If you torque them probably 30 in/lb will do. Just double nut them. Be careful to not to over tighten and cause the steel insert to turn in the case. This could
cause contact with rotating parts in the engine. Notice some of the steel inserts have been ground and at an angle for clearance for the crank counterweights.
As far as leaks go, the inserts are closed off in locations where they extend into the block where oil is present, the others are in the case where they do not
extend into an area that has oil. They simply are bottomed out in a threaded hole.
Hope this helps.
Frank
ONEX 090
N1970T
~55 hours
