nosky2high wrote:Awesome advice, thank you Sir.
Who is your source for #32 bits? I can't seem to find them in the usual places, Wicks, Spruce, etc. Are all of the exterior rivets the same size? do I need any other size dimple dies?
Sounds like if I chose to do the flush rivets that I should invest in a C-frame to better protect the parts in addition to the rivet squeezer you recommended.
Another question for you, i currently have a corded drill as my air compressor is small and unable to support an air drill. What corded drills out there are best for doing this project? Is there an rpm sweet spot?
Thanks again,
Anthony
Anthony - You're welcome!
A C-Frame is nice; but if you want to limit your expenses you can certainly get by without it for the tail build (then get it before doing the Wings & Fuselage).
You should be able to find good #32 (or even #31) drill bits at a good local hardware store. Not a Home Depot-style improvement warehouse; but an old-school honest-to-goodness Hardware store. Several Aircraft supply stores sell them online, too. Here are a few:
Cleaveland Aircraft ToolAircraft Tool & SupplyThe Yard...Also, some places like McMaster-Carr sell them (though not at competitive prices for small quantities).
As for rivet sizes: The only place you'll find a different size rivet is in the wing spar, and if you do any "aftermarket" mods (like a Duckworks wing/landing light). There are some rivets you might want to use on the Fiberglass parts that have a broader head to them; but I haven't worked with those yet and can't claim any expertise with countersinking or dimpling for them (I'm going to do all of the fiberglass bits at the end of the build).
Regarding drills: Air drills are noisy and take a lot of air; but they are LIGHTWEIGHT and HIGH RPM. Those are the two qualities you want most. I started out with some harbor-freight-like air drills, but eventually I sucked it up and bought a $100 "ATS Pro Palm Drill" online. I'm really happy I did, as the lighter weight saves on hand/arm fatigue and makes it easier to line things up for perfect vertical/perpendicular drilling. You can use corded drills and they'll work just fine; but they do tend to be heavy. Whatever you use, higher RPMs is better - and this is the one major knock against cordless drills. I use a Makita for some parts of my project; so its not like you CAN'T use a cordless drill. But their slow RPM range (usually less than 1500 RPMs) makes for a slower process, and the holes tend to turn out more ragged/uneven as the bit "tears" through under heavy pressure - rather than carving small chips. This is fine for pilot holes; but when up-drilling to the final rivet-sized hole I would much rather have a corded or air drill, to make the work faster and the holes more precise. (Pulling rivets through loose/oversized holes is a pain... At the least you have to knock the stem back down into the rivet with a pin-punch and hammer. At worst you have to drill it out and replace the whole thing with a larger rivet)
Now I will state one more time that you CAN build a Sonex with just about any kind of drill. People here have done so. The question is - as always - how quickly do you want your build to go, what is your budget like, and what factors are important to you (for example: if you have tendonitis or other problems that would make holding a heavy drill a bigger deal than it is for the average joe).
Hope this helps!
--Noel
