Plastic wrap on Flaps/Ailerons stuck
Postby jjbardell » Wed Jan 06, 2016 12:43 am
I am trying to get the wrap peeled off my control surfaces. The wrap has been on the surfaces for about 8 years and is so brittle it just flakes in micro pieces. I've tried a hair dryer and heat gun. Any other tips?
Thanks.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: Plastic wrap on Flaps/Ailerons stuck
Postby Corby202 » Wed Jan 06, 2016 3:05 am
A safety razor blade works on the flat surface but basically its slowly slowly with a heat gun.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby WaiexN143NM » Wed Jan 06, 2016 2:08 pm
Hi All,
This happened yrs ago with a glastar project. Suggestions then were to wipe with mineral spirits , let sit and soak in , then try the heat gun. Seemed to work ok. Then wipe w acetone to get any residue off. Give it a try!
Michael Radtke
Postby fastj22 » Wed Jan 06, 2016 9:32 pm
Its a pain. I've recently made some parts using some old stock and had the same issue removing the wrapper. Sometimes you can work a corner up, then roll it onto a long tube to evenly pull it. But mostly it just becomes another reason to cuss.
Postby jjbardell » Fri Jan 08, 2016 1:23 am
Heat gun and straight blade. Finally done. Now I have some sanding and serious polishing to do. Thanks for the tips.
jjbardell
Users browsing this forum: No registered users and 60 guests
