tonyr wrote:If you are using the Airframe as your return path, you are probably better off just running the extra couple of ground wires back to the common firewall ground block.
Otherwise you are relying on the clean bonding of all the parts from the wing tip to the spar root and the fuse angles, wing bolts etc.
Over time any corrosion in these areas will degrade the return path resistance and possibly cause issues later on.
thad14433 wrote:This maybe what your thinking of, the bolts go thru the firewall and you have a ground block on both sides.
http://www.bandc.aero/groundblock2424-t ... llkit.aspx
Sonex1243 wrote: re-threading wire should be relatively easy once the leading edge is cut open for the landing light and tip cap left off.
Users browsing this forum: Google Adsense [Bot] and 61 guests
