rizzz wrote:I've just done my second aerobatic session in my VW powered Sonex this morning, one the first one I nearly dropped out of the loops as well, just look at the video I posted last week in my Sonex #145 thread. Look at the airspeed at the top, I'm very close to 40KT at that point. Following the advise from another Aussie builder, this time around I used a bit more speed, just under 130KT, and pulled slightly less hard, about 3G. Worked much better, I'll upload a video shortly as I also did my first spins this morning.
Onex107 wrote:Something to consider when doing aerobatics. A standard Aerovee installation is not configured for negative G's. The way mine is installed, "0" or negative "G's" could result in fuel discharging from the tank vent and reduced or no pickup for the oil pump. Depending on how you have the crankcase vented, you could loose oil from the vent overboard. The engine will run a few minutes without oil pressure but I don't like the idea of gasoline spraying from the tank vent with the engine at full throttle.
Users browsing this forum: No registered users and 47 guests
