Bryan Cotton wrote:The pressure must be increasing at the static port while pulling G.
sonex892. wrote:Thats great Michael. That looks like way more fun than collecting aircraft and performance data for phase one.
Wow 4G pullup for the loop. For loops I normally aim for 130kts entry then 3G for the pullup.
sonex892. wrote:Looks like a similar routine to my first recorded Sonex aerobatics a few hundred miles up the coast. Search sonex loops and rolls on youtube.
With the spins. I asked my aerobatic instructor about spins and he told me (here in Aus) that spinning is an aircraft specific endorsement and not part of the aerobatic endorsement. He told me I am legally endorsed to intentionally spin decathlons only.
Steve
Sonex 892
VH-ZSX 3300 188hrs
gammaxy wrote:Bryan Cotton wrote:The pressure must be increasing at the static port while pulling G.
I just looked at some of my recorded telemetry and compared the GPS altitude to the indicated altitude. On each landing, my indicated altitude reads about 50 feet lower than it should and approaches the correct value as I slow down.
Interestingly, on a high speed pass, the opposite happens and my indicated altitude seems to be about 100 feet too high.
I suspect this is what happens when you mount a static port below the wing where the pressure measured by the port can be affected by the lift generated by the wing.
a false static pressure reading. This false reading may be caused by abnormally large changes in an aircraft's pitch. A large change in pitch will cause a momentary showing of movement in the opposite direction. Reversal errors primarily affect altimeters and vertical speed indicators.
rizzz wrote:My instructor told me the same. this being the case, how can we ever get endorsed to spin our Sonex? No instructor can take us up and spin it with us as we're surely over the max weight for aero's with 2 people on board.
I believe my A/P had a different idea on this BTW, during the CofA inspection we went over my test flight program I had prepared which includes and aerobatic section with intentional spins being part of it. He did ask me if I knew what the recovery procedure was in a Sonex, that's all.
Anyway, I will spin my Sonex on one of the next flights though, it's not something I like to do intentionally very often but I need to know I can get out of it when it happens, so I'll go high and wear a chute.
I spun the Citabria plenty of times and I understand the recovery procedure is the same.
(I also spun a Pitts a couple of times, normal and flat, that was a slightly different procedure).
