Michael's Sonex #145
First Aerobatics
Postby rizzz » Tue Dec 29, 2015 6:12 am
Nothing fancy yet, just some rolls and a couple of loops:
https://youtu.be/QBKzdHn0Ur4
Still being very careful at this stage, plenty of altitude and wearing a parachute of course.
The rolls went OK, I think I need a bit more speed on the loops (notice especially the second one, nearly spun out there), I'm entering at about 120KT at this stage, pulling up to 4G on the last one.
Great fun though!
Re: Michael's Sonex #145
Postby Bryan Cotton » Tue Dec 29, 2015 9:08 am
Very cool! Looks slightly different down there than up here. Went to the hangar to turn the heat on, got the truck stuck then unstuck, plan to walk back so I am not in the way of the plows. Have you spun it yet?
Postby Darick » Tue Dec 29, 2015 10:20 am
Excellent ! Looks really good.
Nice compact slip/skid ball on the panel..do you remember where you bought it?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Rynoth » Tue Dec 29, 2015 10:47 am
Nice Michael, looks like a blast! If I may offer a suggestion, during your loops, when you're approaching vertical, tilt your head way back (or even do without the cap) so you can find the horizon sooner. It will help you keep the wings level and pull through a straighter loop.
2 questions (just curious): do you have the aerobatic ailerons, and were you going full-deflection during the rolls?
Postby gammaxy » Tue Dec 29, 2015 4:14 pm
Great video. Just a few months ago it seems you were deep in the heart of your engine, now you're doing loops and the plane appears to be flying great.
I noticed your altimeter seems to drop 200-300 feet at the beginning of each loop and by about 100 during the roll entries. It's interesting and I don't know why that would happen. Is it caused by acceleration or by angle of attack? If it is caused by angle of attack, I'd expect it to also happen when landing or taking off. If it was caused by acceleration, I'd expect it to cause you to actually gain altitude in a steep turn. Maybe it only happens when the rate of acceleration or angle of attack are changing?
Postby rizzz » Tue Dec 29, 2015 5:07 pm
Bryan Cotton wrote:Very cool! Looks slightly different down there than up here. Went to the hangar to turn the heat on, got the truck stuck then unstuck, plan to walk back so I am not in the way of the plows. Have you spun it yet?
No spins yet, I need to build up a bit more confidence first.
Postby rizzz » Tue Dec 29, 2015 5:08 pm
Darick wrote:Excellent ! Looks really good.
From Spruce, here it is:
https://www.aircraftspruce.com/catalog/ ... ckkey=7510
Postby rizzz » Tue Dec 29, 2015 5:13 pm
gammaxy wrote:Great video. Just a few months ago it seems you were deep in the heart of your engine, now you're doing loops and the plane appears to be flying great.
Yeah,
Heartbreaking at the time, as was me stuffing up the wing rigging, but in hindsight these were all just minor setbacks.
gammaxy wrote:I noticed your altimeter seems to drop 200-300 feet at the beginning of each loop and by about 100 during the roll entries. It's interesting and I don't know why that would happen. Is it caused by acceleration or by angle of attack? If it is caused by angle of attack, I'd expect it to also happen when landing or taking off. If it was caused by acceleration, I'd expect it to cause you to actually gain altitude in a steep turn. Maybe it only happens when the rate of acceleration or angle of attack are changing?
I believe it's the G forces that do that, I had never noticed it before.
Maybe someone with a bit more experience/knowledge in aerobatics can comment on this?
Postby rizzz » Tue Dec 29, 2015 5:15 pm
Rynoth wrote:Nice Michael, looks like a blast! If I may offer a suggestion, during your loops, when you're approaching vertical, tilt your head way back (or even do without the cap) so you can find the horizon sooner. It will help you keep the wings level and pull through a straighter loop.
My instructor used to yell at me about not looking for the horizon soon enough, also during the pull up I tend to forget to look at the horizon over the wingtip.
I haven't done aero's since I last flew the Citabria which is a couple of months ago now, I'll need to get back into the routine.
I have the standard ailerons and yes, I was going close to full deflection on the ailerons I think combined with about half rudder (or so).
Postby Bryan Cotton » Tue Dec 29, 2015 5:50 pm
The pressure must be increasing at the static port while pulling G. Never noticed that in the pitts. When I was first starting, I thought my loops were perfect as I started and ended on section lines. This was down in Florida. My instructor pointed out I was changing heading by 90 degrees with each loop. Whoops!
Return to Photo Album
